  2. Renault Trafic
  3. Trafic-Mechanik
Central locking help
  • ColinO
  • 29. September 2026 um 17:12
  • ColinO
    Hi hive mind
    2014/15 Renault Trafic 1.6dci
    Looking for some help on central locking:
    Had to replace both front door latches as the nipple on the cables snapped off -yes both of them within a month of each other.
    Second hand latches fitted but now the doors will not unlock and lock properly. I cant open either door from outside.
    What am I missing?
    Do I need to reset software?
    Could it be the battery system management thingummy?
    I can't seem to find out any information about it or anyone that knows anything about it!
    Cheers
    Col
    • 29. September 2026 um 21:19
    Colin,
    I would not suspect the battery management system or a software reset as the first thing.
    Given that the problem appeared immediately after replacing both front door latches, I would first concentrate on the replacement locks and the mechanical Bowden cables.
    On the Trafic III (X82), the central locking motor is part of the door latch assembly, but the outside door handle operates the latch mechanically via a Bowden cable.
    The first thing I would check
    Remove the door trim again and check the Bowden cable from the outside handle to the latch:
    • Is the cable nipple properly seated in the latch lever?
    • Is the outer cable sheath fully clipped into its retaining bracket?
    • Is the cable routed correctly and not kinked?
    • Does the latch lever move through its full range when the outside handle is pulled?
    • Does the latch actually release when the lever is moved manually?
    This is particularly important because you mentioned that the original problem was the cable nipple breaking off. If the replacement cable is not seated correctly, the outside handle can move normally but simply doesn't move the latch far enough to release the door.
    A very useful test
    With the door open, operate the central locking with the remote and watch/listen to the latch.
    Does the locking motor actually operate?
    Then try the inside handle and outside handle separately.
    The results can tell you quite a lot:
    What happensMost likely area
    No sound/movement from the latchElectrical supply, connector, wiring, latch motor or control
    Locking motor operates but outside handle doesn't open doorBowden cable / outside handle / latch mechanism
    Inside handle opens the door but outside handle doesn'tVery likely Bowden cable or outside handle adjustment
    Locks but won't unlockLatch mechanism or electrical actuator
    Locks and immediately unlocks againDoor/latch position switch or door-status signal
    Both replacement latches have no electrical operationCheck common power supply/wiring/control before blaming both latches
    I wouldn't reset anything yet
    A software reset or disconnecting the battery shouldn't be necessary just because the front door latches have been replaced.
    If the problem started immediately after fitting the second-hand latches, I would first verify the mechanical installation and the electrical connectors.
    The battery management system would be quite low on my list of suspects for this particular symptom.
    One other thing worth checking is the part numbers of the two replacement latches. The left and right front latches are different, and the Trafic III shares components with the Opel/Vauxhall Vivaro B and Nissan NV300, so it's worth making absolutely sure you have the correct versions.
    If you can tell us:
    1. Can you open both front doors from the inside?
    2. Do you hear the locking motors operating when you press the remote?
    3. Do the interior locking buttons/knobs move?
    4. What are the part numbers on the two replacement latches?
    we should be able to narrow this down quite quickly.
    Greetz Micha
  • ColinO
    • 1. Oktober 2026 um 11:29
    Hi Many thanks for this. I am going mad trying to figure it out.
    I have checked the cables and they look properly seated and functional.
    What is curious is that once the doors have been opened from the inside (from a locked state) they will no longer shut properly. The door latch will not engage with the striker ring. If i press the internal "lock" button I can hear the door lock actuators lock and then immediately unlock the doors (as in the Door/latch position switch or door-status signal). The doors will now shut and engage with the striker plate as normal but are still unable to be opened from the outside.
    In answer to your questions:
      Yes both door handles open the doors
      Yes
      NA
      Left door latch - 805039146R
    Right door latch - 805025102R
    Vehicle is 2014 Trafic 1.6DCi
    Thanks
    Colin
    • 1. Oktober 2026 um 12:29
    Colin,
    That additional information changes the diagnosis quite a bit. The important clue is that the latch will not remain in the latched position until you operate the interior lock, and then the central locking immediately unlocks again.
    I would now put the door/latch position sensing and the compatibility/function of the replacement latches much higher on the list.
    I checked the two part numbers you supplied. 805025102R is definitely listed as the front-right latch for the Trafic III X82, including 2014/2015 vehicles. The Renault parts catalogue also lists 805025102R as a front-right electromagnetic lock.
    The left-hand number 805039146R, however, is the one I would investigate further before doing anything with the battery or software. The Renault parts catalogue shows several very similar LH X82 latch numbers, including 805039145R, 805039405R and 805032854R, depending on vehicle configuration.
    The really interesting part of your test
    You have essentially demonstrated this sequence:
    1. Door is locked.
    2. You unlock/open it from inside.
    3. After opening, the latch will not catch the striker.
    4. You press the interior lock button.
    5. You hear the actuator lock.
    6. It immediately unlocks again.
    7. Now the latch will mechanically catch the striker.
    8. The door closes normally.
    9. But the exterior handle still cannot open it.
    That makes me suspicious that the replacement latch is not correctly reporting its mechanical state to the vehicle, or that the latch itself isn't reaching the correct internal position.
    The fact that the central locking immediately reverses the locking command is particularly significant. That is exactly the sort of behaviour you get when the vehicle believes that a door hasn't reached the expected state.
    I would do one very simple test next
    With the door open, don't use the door handle.
    Take a screwdriver and carefully rotate the latch itself over the striker as though the door were closed.
    You should be able to put the latch into the first/closed position and then the fully closed position.
    Then operate the central locking.
    Watch/listen to what happens.
    Do this separately on both doors.
    Important: before closing the actual door again, release the latch with the door handle. Otherwise you can accidentally close the door with the latch already in the closed position.
    If the latch will not stay mechanically latched with the door open, that's a strong indication that the replacement latch itself is the problem.
    Even more useful: compare the old and replacement locks
    Since you still have the original locks, if possible put them side-by-side.
    Compare:
    • connector
    • number of pins
    • lever positions
    • cable attachment points
    • latch mechanism
    • part number
    • electrical actuator
    • any additional microswitch/sensor arrangement
    I would be particularly interested in whether 805039146R and 805025102R are actually the exact variants specified for your particular 2014 vehicle, rather than merely being X82 front-door locks.
    The X82 catalogue contains several visually similar front locks with different specifications, including versions with electromagnetic locking/deadlocking.
    I would NOT blame the battery management system yet
    Your test results actually argue against that.
    You have:
    • functioning actuators
    • functioning central locking command
    • functioning interior mechanical release
    • both doors behaving in essentially the same way after the latch replacement
    That is much more suggestive of latch-state feedback / incorrect latch variant / faulty second-hand latches than a BMS problem.
    And because both replacement locks are second-hand, there's another possibility worth considering: you may simply have installed two locks with an internal microswitch or mechanism that is faulty/worn.
    One diagnostic check would settle this very quickly
    If you have Renault CLIP, Launch, Autel, iCarsoft, Thinkdiag etc., go into the relevant UCH/BCM/body-control module live data and look for something along the lines of:
    • Driver door status: OPEN/CLOSED
    • Passenger door status: OPEN/CLOSED
    • Driver door lock status
    • Passenger door lock status
    • Door latch/lock position
    • Central locking command
    • Door handle/lock switch status
    Then operate the latch by hand with the door open.
    If the physical latch is in the closed position but the diagnostic data still says DOOR OPEN, you've found the problem.
    If the diagnostic data changes correctly between OPEN/CLOSED, but the central locking still immediately reverses, then I'd investigate the actual lock-state/locking position signal and the exact latch variant.
    I would not buy another latch or start resetting the vehicle until that live-data test has been done.
    Greetz Micha
  • ColinO
    • 1. Oktober 2026 um 13:15
    Thanks again. Plenty to think about!
    it will be a day or so before I can investigate further. I will, of course, let you know.
    Colin
    • 1. Oktober 2026 um 15:42
    :thumbup:
  • Locks
  • front doors
