  2. Renault Captur
  3. Renault-Captur-Teile und Zubehör
Captur 2013 where to find plastic clips to fix roof spoiler
  • Renau Car
  • 5. Mai 2026 um 23:11
  • Renau Car
    Hi THere,
    Where can I find these separate white and black (I do not know why there are two colors, they seem identical) clips that fixes the flat sunken black roof spoiler of a Captur 2013. The item number of the roof spoiler is SILVATRIM <260> 09/07/13 01:22 >ALU.PVC< >POM< >ASA< IND A 738535261R/738522314R
    Thanks in advance for your help.
    • 6. Mai 2026 um 09:16
    Renau,
    The numbers you found are not really for the rear roof spoiler. They identify the left/right roof moulding / roof trim strips:
    • 738535261R = left roof moulding / “MLDG-LH ROOF”
    • 738522314R = right roof moulding / “MLDG-RH ROOF”
      Part catalogues list them under Exterior trims / Spoiler, which is probably why it is confusing.
    For these roof trims, Renault’s catalogue shows the roof moulding and screws, but I did not find the white/black plastic clips listed as a separate Renault spare part for that trim. That usually means the clips are supplied with the complete roof moulding, or Renault expects the whole strip to be replaced.
    You can buy the complete trim strips here / search using these terms:
    New OEM
    • Search: 738535261R Zierleiste Dach links Captur
    • Search: 738522314R Zierleiste Dach rechts Captur
    • German listings call them “Zierleiste Dach” or “Zierleiste Dachregenrinne”. I found new examples around €90–100 each.
    Used
    • Search: Renault Captur roof trim bar molding cover 738535261R
    • Used-part sites list the left roof trim, for example around €50.
    Clip specialists
    • VehicleClips lists Renault Captur Mk1 trim fasteners and says they may be able to help if a specific clip is not shown.
    • There is also a Renault exterior roof moulding clip sold under 8200056981, but I would only use this after comparing the shape/measurements with your old clip, because I could not confirm it as the exact Captur roof-strip clip.
    My practical recommendation: take one intact white/black clip off, measure it, photograph it from top/side/bottom, and contact VehicleClips, Restagraf supplier, or a Renault dealer parts desk. Ask specifically for the retaining clips for Captur I roof moulding 738535261R / 738522314R. If they cannot supply the clip separately, the safest repair is replacing the complete roof moulding strip.
    Greets Micha
  • Renau Car
    • 7. Mai 2026 um 10:08
    Thanks for your tips. I am going to work with them as far as possible. But in the end I think I am going to repair the few partly broken clips in another (magnetic) one-way between the spoiler and the roof. Starting point is that after the actual rare dismantling of the spoiler (because of "wrapping" the roof) it will never demantled again.
  • Renau Car
    • 22. Mai 2026 um 13:14
    Well I didn't find those spare parts for a reasonable price. Happely enough most of the clips were intact. Those who did not clamp correctly are glued on the rail.
    The roofrail fits again solid on its black (instead of the UV-damaged original metalic orange) protectively wrapped roof.
  • Basti 20. August 2026 um 13:30
  • Renault Captur 2013
  • spoiler clips
  • roof clips
