OBD-Fehlercode P0038
  • 24. Juli 2012 um 12:41
    Hallo Leute
    habe meinen Laggi mal ausgelesen und habe folgenden Fehlercode: P0038
    Dieser Bedeutet:
    HO2S Heater Control Circuit High
    What does this mean?
    OBD Code P0038refers to
    Oxygen Sensors (O2S) or Heated Oxygen Sensors (HO2S) need to reach a minimum operating temperature of 750 degrees F to produce an accurate voltage signal. The faster the heated oxygen sensor reaches that temperature the faster the sensor will start sending an accurate signal to the Engine Control Module (ECM). In order to achieve the require temperature, a heater element is included inside the heated oxygen sensor. The ECM controls the heated oxygen sensor heater element based on signals from the engine coolant temperature and engine load. The ECM controls the heater element circuit by allowing current flow to ground. The ECM monitors the voltage signal received through the heater element circuit and determines the state of the circuit by comparing the voltage detected with the factory specifications.
    Symptoms
    Possible sumptoms of OBD code P0038
    - Engine Light ON (or Service Engine Soon Warning Light)
    Causes
    Possible causes of OBD code P0038
    - Heated Oxygen Sensor (H2OS) Bank 1 Sensor 2 circuit open shorted to ground - Heated Oxygen Sensor (H2OS) Bank 1 Sensor 2 circuit poor electrical connection - Faulty Heated Oxygen Sensor (H2OS) Bank 1 Sensor 2 circuit - Heated Oxygen Sensor (H2OS) Bank 1 Sensor 2 circuit fuse - Faulty Engine Control Module (ECM) The Error code is generally activated on detection of the following conditions: The P0038 is set when the ECM detects an excessively high voltage through the heated oxygen sensor heater circuit
    Possible Solutions
    HO2S Heater Control Circuit High Bank 1 Sensor 2 is the generic definition for the P0038; however your vehicle's manufacturer may have a different definition and information for the P0038 code.
    Hat der Diesel ne beheizte Lambdasonde? eigentlich ja nicht, oder ist damit der LMM gemeint?
    Oxygen Sensor ist ja eigentlich die Lambdasonde
    Mfg Basti
  • lace
    • 24. Juli 2012 um 20:16
    hi jungs
    habe da gleich auch ein freage uber obd geräte , ich habe ein laguna 2 phase1 bj 05-2002 kan man da auch ein obd gerate anschließen, und so ja wo tut mann das,
    Da ich mahl gelesen habe das das erst ab 2003 modellen geht.
    gr lace
    • 24. Juli 2012 um 22:27
    Zitat von lace
    hi jungs
    gr lace
    Alles anzeigen
    Genau, Diesel haben erst ab 2003 einen Fehlerspeicher, das geht also bei deinem leider nicht.
    Aber weiter mit dem Problem von Basti, bitte :D
    P.S. bitte demnächst die Suche benutzen, dieses Thema hatten wir hier nämlich schonmal in einem Bericht. ;)
