  2. Renault Trafic
  3. Trafic-Elektronik
Renault Trafic M9r error P0100 and P0409
  • Cristiano Pio
  • 3. Mai 2026 um 20:51
  • Cristiano Pio
    Good evening everyone! My name is Cristiano Pio.
    I own a 2009 Renault Trafic 2.0 dCi 66 kW with the M9R engine. No DPF.
    The vehicle starts and runs, but it has lost some power. The EGR valve is clean.
    My vehicle has fault codes P0100 and P0409. I have already tested the EGR valve and installed a new MAP sensor, but the error persists. I have checked the wiring and everything seems correct.
    Please help me solve this problem. Your experience or any advice you could provide would be greatly appreciated. Thank you.
    (**P = pin**, **V = volts**)
    Dashboard ON and engine OFF.
    Sensors disconnected.
    **MAF Sensor Connector**
    P1 4.96 V
    P2 0.00 V
    P3 No pin
    P4 12.54 V
    P5 4.97 V
    P6 0.00 V
    **MAP Sensor Connector**
    P1 4.98 V
    P2 0.00 V
    P3 0.001 V
    **EGR Valve Connector**
    P1 0.00 V
    P2 4.98 V
    P3 No pin
    P4 0.00 V
    P5 1.22 V
    P6 0.01 V
    **Throttle Body Connector**
    P1 4.52 V
    P2 4.98 V
    P3 4.31 V
    P4 No pin
    P5 0.00 V
    P6 0.00 V
    **Glow Plug Relay Connector**
    P1 0.00 V
    P2 0.00 V
    P3 11.50 V
    P4 12.49 V
    P5 0.00 V
    P6 0.00 V
    P7 0.00 V
    P8 3.50 V
    If you wish, I can also help interpret these voltages for fault diagnosis
  • Online
    nordinvent
    • 3. Mai 2026 um 23:22
    Cristiano,
    Your voltage list is actually very useful. The important clue is this:
    You have P0100 and P0409 at the same time, and both systems use the ECU’s 5 V reference / sensor ground / signal monitoring.
    P0100 is a MAF circuit fault, and P0409 is an EGR position/sensor circuit fault, not simply “dirty EGR.”
    What looks normal
    MAP sensor connector
    With the MAP disconnected, this looks normal:
    MAP pinYour valueMeaning
    P14.98 V5 V reference present
    P20.00 Vsensor ground present
    P30.001 Vsignal wire pulled low/open with sensor disconnected
    So the MAP circuit itself is probably not the cause, especially since you already replaced the MAP sensor.
    MAF connector
    Your MAF values also look mostly logical:
    MAF pinYour valueMeaning
    P14.96 V5 V reference / signal supply
    P20.00 Vground
    P412.54 Vignition/battery supply
    P54.97 Vsignal/reference line
    P60.00 Vground
    A MAF with 12 V supply, 5 V reference and grounds present does not prove the MAF is good, but it means the connector is not obviously dead.
    The suspicious part: EGR connector
    Your EGR readings:
    EGR pinYour valueComment
    P10.00 Vlikely motor/control side
    P24.98 V5 V reference, OK
    P3no pinOK
    P40.00 Vground or motor/control
    P51.22 Vsuspicious
    P60.01 Vground/control
    The key one is EGR P5 = 1.22 V with the EGR disconnected.
    On many Renault/Vivaro/Trafic M9R EGR systems, the EGR has a motor plus an internal position sensor. P0409 relates to the EGR position/sensor circuit, and Renault/Trafic owners have reported this exact type of P0409 as an EGR sensor circuit issue rather than only a dirty valve.
    With the valve unplugged, the EGR position signal should usually be either pulled up near 5 V, pulled down near 0 V, or show a clearly defined ECU bias voltage depending on ECU design. 1.22 V is not automatically impossible, but it is suspicious if the ECU interprets it as an invalid EGR position signal.
    My strongest suspicion
    I would not replace the MAP again. I would focus on one of these:
    1. EGR position signal wire problem
    2. EGR internal position sensor fault despite the valve “testing” mechanically
    3. shared 5 V / sensor ground disturbance when components are plugged in
    4. MAF signal plausibility fault caused by EGR/throttle air-flow mismatch
    5. less likely: ECU input fault
    P0100 and P0409 together can happen because the ECU compares MAF air flow, MAP pressure, throttle flap position and EGR position. If the ECU commands EGR movement but the EGR feedback is wrong, the measured air mass may not match expectation, so a MAF circuit/range fault can be triggered even when the MAF wiring looks okay.
    Do these tests next
    1. Test with sensors plugged in, not only disconnected
    Your current measurements are with sensors disconnected. That checks supply, but not loaded operation.
    Back-probe with everything connected, ignition ON:
    EGR position signal
    Find which pin changes when the EGR is commanded with diagnostic tool. The signal should move smoothly, usually somewhere inside roughly 0.5–4.5 V, not jump, drop out, or stay fixed.
    MAF signal
    With engine idling, the MAF signal or live-data air mass must be plausible and stable. If MAF live data is frozen, zero, maximum, or jumps wildly, then P0100 becomes more direct.
    2. Unplug EGR, clear codes, start engine, see what returns first
    Do this as a diagnostic test only:
    1. unplug EGR
    2. clear all codes
    3. ignition off/on
    4. start engine
    5. read codes immediately
    Expected result: you may get an EGR open-circuit type fault.
    Important question: does P0100 return immediately too?
    If P0100 disappears or changes when EGR is unplugged, the EGR or its wiring is probably dragging down or corrupting a shared sensor line. There are similar cases on Trafic/Vivaro platforms where a bad EGR affected the 5 V reference and caused air-flow related faults.
    3. Check voltage drop on sensor ground
    Do not only check continuity with an ohmmeter. Do a voltage-drop test.
    Ignition ON, sensors connected:
    • multimeter positive to battery negative
    • multimeter negative to MAP/MAF/EGR sensor ground pin
    You want very close to 0.00 V.
    If you see for example 0.1–0.5 V, the sensor ground is bad even if continuity “seems okay.”
    Also test with engine running and while wiggling the loom.
    4. Wiggle-test the loom near EGR/MAF/throttle
    On the Trafic/Vivaro/Primastar M9R, the loom around the EGR/throttle/intake area gets heat, oil mist and vibration. Look especially for:
    • rubbed insulation near the EGR cooler/intake pipe
    • oil inside connector plugs
    • spread female terminals
    • green corrosion
    • broken wire inside insulation near the connector strain relief
    • poor ECU connector pins
    A wire can show continuity with a meter but fail under vibration or load.
    5. Compare EGR command vs EGR feedback with live data
    With CLIP, Delphi, Autel, Launch, etc., look at:
    • EGR command %
    • EGR actual position %
    • MAF kg/h or mg/stroke
    • MAP pressure
    • throttle flap command / position
    At ignition ON engine OFF, EGR command and feedback should be believable and not stuck at an impossible value.
    At idle:
    • command EGR open/closed with actuator test if possible
    • MAF should change when EGR opens/closes
    • EGR feedback should follow command
    If command changes but feedback stays fixed, P0409 is justified.
    About the throttle body voltages
    Your throttle body connector has several 4–5 V readings:
    Throttle pinYour value
    P14.52 V
    P24.98 V
    P34.31 V
    P50.00 V
    P60.00 V
    That does not immediately look wrong with the unit disconnected. The throttle flap on these engines is used for EGR control and shutdown, so if the throttle position feedback is wrong, it can also disturb EGR/MAF plausibility. But because your stored codes are P0100 + P0409, I would check EGR feedback first.
    Most likely repair path
    My order would be:
    1. Back-probe EGR position signal connected.
    2. Check sensor ground voltage drop under load.
    3. Check whether EGR P5 changes smoothly during actuator command.
    4. If P5 is stuck around 1.2 V or jumps: repair EGR signal wire or replace EGR valve with a known-good/OE-quality unit.
    5. If EGR feedback is perfect, then test MAF live data and MAF signal under running conditions.
    6. Only suspect ECU after proving 5 V, ground, signal wire continuity and loaded signal behavior at the ECU pins.
    My practical bet from your numbers: the fault is around the EGR position feedback circuit, especially the P5 line, and P0100 is probably a consequence of air-flow plausibility rather than the original fault.
    Greetz Micha
  • Basti 1. August 2026 um 23:30
  • Renault Trafic 2.0 dCi
